ok to strip?
Dumb question, but I'll ask anyhow
I have what I think is a 52 cathedral.
Some jackass thought the cabinet needed improvement..
Want to see if these were photophinish at all.
Too early a radio for photophinish I think.
Tim
ok to strip? - by TimC - 10-27-2014, 04:53 PM
RE: ok to strip? - by Ron Ramirez - 10-27-2014, 05:10 PM
RE: ok to strip? - by jerryhawthorne - 10-27-2014, 06:14 PM
RE: ok to strip? - by Arran - 10-27-2014, 09:38 PM
There are currently 8996 online users. [Complete List]
» 1 Member(s) | 8995 Guest(s)
