My Bakelite Peeve
Uffda Wrote:I am not peeved enough to try Syl's test so I went with Bill's. Sho 'nuff it's bakelite.
Thanks for the offer Syl, but I think I will stick with just this one for now. I tried rubbing
the case with Brasso and then soaked it in Glayzit and polished vigorously. Neither
worked well. It has sort of a feathered oxidation look all over. What next? I have some
Mother's Mag polish. Yes? Novus 3-2-1 ?
Mother's mag and blue polish are great, then Mother's mag scratch remover for the finishing touch.
Syl
My Bakelite Peeve - by Uffda - 11-11-2008, 02:12 AM
Re: My Bakelite Peeve - by Ron Ramirez - 11-11-2008, 09:50 AM
Re: My Bakelite Peeve - by Uffda - 11-11-2008, 03:08 PM
Re: My Bakelite Peeve - by Syl - 11-11-2008, 04:42 PM
Re: My Bakelite Peeve - by Uffda - 11-11-2008, 06:09 PM
Re: My Bakelite Peeve - by exray - 11-11-2008, 06:51 PM
Re: My Bakelite Peeve - by Syl - 11-11-2008, 10:16 PM
Re: My Bakelite Peeve - by Syl - 11-11-2008, 10:24 PM
Re: My Bakelite Peeve - by Uffda - 11-11-2008, 10:48 PM
Re: My Bakelite Peeve - by Syl - 11-11-2008, 10:57 PM
Re: My Bakelite Peeve - by Uffda - 11-11-2008, 11:41 PM
Re: My Bakelite Peeve - by exray - 11-12-2008, 01:51 AM
Re: My Bakelite Peeve - by Uffda - 11-12-2008, 04:27 AM
Philco 91 Tuning Condenser
There are currently 8681 online users. [Complete List]
» 2 Member(s) | 8679 Guest(s)
