my 4 tube battery set 39-70 has 5 tubes and an AC cord??
I also found these pages, with typical AA5 schematics. Hope they help.
http://www.wa2ise.com/#aa5
The latter is the home of the former. Lots of information there you may find either helpful or interesting.
RE: my 4 tube battery set 39-70 has 5 tubes and an AC cord?? - by mikethedruid - 10-30-2014, 08:42 PM
