1935 model 59-C
I'd do it the easy way. Just verify that the LO is working by listening for it in another receiver. If you can't hear it it isn't working. Listen for it a both ends of the band if it's working at the high end and not at the low end chances are that the coil was repaired but didn't have enough turns rewound on the feedback winding. Don't know how many it had but I would think 20-25 should be enough.
1935 model 59-C - by NostalgiaRadioTime - 11-01-2014, 08:41 PM
RE: 1934 model 58-C - by NostalgiaRadioTime - 11-01-2014, 11:09 PM
RE: 1934 model 58-C - by Ron Ramirez - 11-02-2014, 09:07 AM
RE: 1934 model 58-C - by Ron Ramirez - 11-02-2014, 09:11 AM
RE: 1934 model 58-C - by Radioroslyn - 11-02-2014, 09:36 AM
RE: 1934 model 58-C - by NostalgiaRadioTime - 11-02-2014, 01:54 PM
RE: 1934 model 59-C - by NostalgiaRadioTime - 11-02-2014, 02:02 PM
