Philco 39-30 fixerupper
Hi Guys.....
Thanks for the information.
This radio must have come from my area of the country when new because two of the push buttons are marked for WCCO and KSTP stations.
I took a closer look at the socket for the 6A7  tube and it's made by American Phenolic Corp. Chicago.  This type socket was added by a repairman and is held in place with a retaining clip under the chassis.  I can see where they removed the hollow rivets holding the original 8 pin socket to the chassis.
Yes, the poor rubber wiring from the power transformer must be repaired.  Other than that the power transformer ohms ok.
G.
Philco 39-30 fixerupper - by philconerd - 11-03-2014, 12:54 PM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-03-2014, 01:25 PM
RE: Philco 39-30 fixerupper - by Arran - 11-04-2014, 01:26 AM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-04-2014, 08:44 AM
RE: Philco 39-30 fixerupper - by philconerd - 11-04-2014, 12:30 PM
RE: Philco 39-30 fixerupper - by Arran - 11-05-2014, 01:02 AM
RE: Philco 39-30 fixerupper - by philconerd - 11-05-2014, 10:39 PM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-05-2014, 10:46 PM
RE: Philco 39-30 fixerupper - by Arran - 11-05-2014, 10:53 PM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-05-2014, 10:59 PM
RE: Philco 39-30 fixerupper - by Arran - 11-06-2014, 12:24 AM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-06-2014, 07:39 AM
RE: Philco 39-30 fixerupper - by Kekoa - 11-06-2014, 01:53 PM
RE: Philco 39-30 fixerupper - by philconerd - 11-07-2014, 11:57 AM
There are currently 5954 online users. [Complete List]
» 2 Member(s) | 5952 Guest(s)
