Philco Model 91 shadowmeter
Hi Dave,
The shadow meters I have here that are working are from the 650B and 116B models. They are measuring between 1100 and 1200 ohms as supplied by Philco. I don't know what readings would be normal for the shadow meter on the model 91. Icon_smile
Ed
Philco Model 91 shadowmeter - by Dave Slusarczyk - 11-12-2008, 11:51 PM
Re: Philco Model 91 shadowmeter - by Ron Ramirez - 11-13-2008, 12:00 AM
Re: Philco Model 91 shadowmeter - by etech - 11-13-2008, 12:30 AM
Re: Philco Model 91 shadowmeter - by etech - 11-13-2008, 09:44 AM
There are currently 3463 online users. [Complete List]
» 1 Member(s) | 3462 Guest(s)
