Philco Model 91 shadowmeter
Thanks Ed,
Someone had bypassed the open coil in the shadowmeter years ago. They had used an 1100 ohm resistor. I am going to assume that with your help and Rons plus the resistor in the set that I will need to shoot for the 1100 ohm range. I did study the wire I pulled off the coil again under a lighted magnifying glass and it now appears to be smaller than 40 gauge. The smallest I have is 44 gauge. I will try it tomorrow evening and see what measurement I end up with.
Thnaks guys!!
Dave
Philco Model 91 shadowmeter - by Dave Slusarczyk - 11-12-2008, 11:51 PM
Re: Philco Model 91 shadowmeter - by Ron Ramirez - 11-13-2008, 12:00 AM
Re: Philco Model 91 shadowmeter - by etech - 11-13-2008, 12:30 AM
Re: Philco Model 91 shadowmeter - by Dave Slusarczyk - 11-13-2008, 12:36 AM
Re: Philco Model 91 shadowmeter - by etech - 11-13-2008, 09:44 AM
There are currently 11396 online users. [Complete List]
» 2 Member(s) | 11394 Guest(s)
