Philco 90 Dial movement
I successfully repaired the dial mechanism on my 90 cathedral. The hole in the bracket was worn, causing the spring behind the pinch disc to tilt the shaft up slightly. This caused the mechanism to slip. From the junkpile, I found a piece of quarter-inch ID brass tubing, part of the dial on one of those 1940s single-knob Zenith sets. I reamed the hole in the bracket big enough to fit the tubing's OD and soldered it in place, then cut it short enough so it wouldn't interfere with the knob. A drop of oil in the bearing, and it was as good as new.
If you have to do this repair, the rivets in the bracket will have to be carefully drilled out.
Tim KA3JRT
Tim KA3JRT
Philco 90 Dial movement - by Guest - 10-02-2008, 03:21 PM
Re: Philco 90 Dial movement - by Chuck Schwark - 10-02-2008, 03:39 PM
Re: Philco 90 Dial movement - by etech - 10-12-2008, 11:01 AM
Re: Philco 90 Dial movement - by Ron Ramirez - 10-12-2008, 11:10 AM
Re: Philco 90 Dial movement - by etech - 10-12-2008, 07:50 PM
Re: Philco 90 Dial movement - by Ron Ramirez - 10-12-2008, 10:35 PM
Re: Philco 90 Dial movement - by Guest - 10-13-2008, 07:23 AM
Re: Philco 90 Dial movement - by etech - 10-13-2008, 08:26 AM
Re: Philco 90 Dial movement - by Ron Ramirez - 10-13-2008, 07:06 PM
Re: Philco 90 Dial movement - by Tim Tress - 11-13-2008, 09:14 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
There are currently 1563 online users. [Complete List]
» 1 Member(s) | 1562 Guest(s)
