Philco Canada 39 or 41-722 Tropic
I started on this project yesterday, and here's the progress as of mid-morning today:
[Image: http://www.philcoradio.com/images/phorum...e00002.jpg]
In this case, the paper caps you see are the new capacitors. Icon_smile
I'm going by the 41-722 service info because the Canadian diagram is much harder to read, plus it has no under-chassis drawing. I have found that the circuitry agrees with the 41-722 save for the power supply as mentioned in my first post in this thread.
There is a 5 pF mica cap, part (16A) on the 41-722 schematic. One lead of this mica cap broke off short as I was replacing resistor (7), so it will require replacement.
I'll also have to come up with a speaker connector - the original (the part that plugs into the back of the speaker) is missing. Unlike most 1939-1942 Philcos which use four terminals, this one uses three; much like a mid-30s RCA. I do not know if an RCA 3-pin connector would be an exact fit or not as I do not own any of those sets.
RE: Philco Canada 39 or 41-722 Tropic - by Ron Ramirez - 11-05-2014, 06:16 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-05-2014, 11:12 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-08-2014, 01:36 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-08-2014, 11:57 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-09-2014, 12:18 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-09-2014, 11:44 AM
RE: Philco Canada 39 or 41-722 Tropic - by Warren - 11-09-2014, 11:32 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-10-2014, 12:58 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-11-2014, 12:45 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-12-2014, 03:47 AM
RE: Philco Canada 39 or 41-722 Tropic - by sam - 11-12-2014, 04:56 AM
RE: Philco Canada 39 or 41-722 Tropic - by KCMike - 11-12-2014, 08:19 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-13-2014, 01:30 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-14-2014, 03:04 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
