Philco 39-30 fixerupper
This photo of the 7 pin socket will be helpful to show the location of the 6A7 tube on the chassis.
Philco 39-30 fixerupper - by philconerd - 11-03-2014, 12:54 PM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-03-2014, 01:25 PM
RE: Philco 39-30 fixerupper - by Arran - 11-04-2014, 01:26 AM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-04-2014, 08:44 AM
RE: Philco 39-30 fixerupper - by philconerd - 11-04-2014, 12:30 PM
RE: Philco 39-30 fixerupper - by Arran - 11-05-2014, 01:02 AM
RE: Philco 39-30 fixerupper - by philconerd - 11-05-2014, 10:39 PM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-05-2014, 10:46 PM
RE: Philco 39-30 fixerupper - by Arran - 11-05-2014, 10:53 PM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-05-2014, 10:59 PM
RE: Philco 39-30 fixerupper - by Arran - 11-06-2014, 12:24 AM
RE: Philco 39-30 fixerupper - by Ron Ramirez - 11-06-2014, 07:39 AM
RE: Philco 39-30 fixerupper - by Kekoa - 11-06-2014, 01:53 PM
RE: Philco 39-30 fixerupper - by philconerd - 11-07-2014, 11:57 AM
There are currently 5219 online users. [Complete List]
» 5 Member(s) | 5214 Guest(s)
AvatarAvatarAvatarAvatar
