Zenith with candohm resistor
Hi guys. I picked up a Zenith 8H023 AM/FM (Schematic)  made in 1946. Besides all of the rubber coated wire that I'll have to replace, it has a candohm resistor that is burned on one side. Looking at the schematic all I see is 30 and 67 (that's also printed on the resistor).  The parts list is so bad that I can't read it. Does anyone know what the values are? Will it be OK to replace it with 10W resistors once I know the correct values?
Thanks
Eric
The Villages, FL
Zenith with candohm resistor - by Eric Adams - 11-06-2014, 11:44 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-07-2014, 08:26 AM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 11:19 AM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 12:07 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-07-2014, 12:34 PM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 02:18 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-07-2014, 03:26 PM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 03:40 PM
RE: Zenith with candohm resistor - by Phlogiston - 11-07-2014, 05:43 PM
RE: Zenith with candohm resistor - by Arran - 11-12-2014, 04:26 AM
RE: Zenith with candohm resistor - by Geoff - 11-11-2014, 02:04 PM
RE: Zenith with candohm resistor - by Phlogiston - 11-12-2014, 11:41 AM
RE: Zenith with candohm resistor - by Eric Adams - 11-13-2014, 10:43 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-13-2014, 11:49 PM
RE: Zenith with candohm resistor - by jcassity - 04-02-2017, 11:04 AM
RE: Zenith with candohm resistor - by morzh - 04-02-2017, 01:49 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4801 online users. [Complete List]
» 3 Member(s) | 4798 Guest(s)
