Zenith with candohm resistor
Icon_thumbup
Let us know how it works out. If it is like my Philco Tropic 42-761EZ which is also an AC/DC set in which I had to replace two Candohms with two new resistors...and increased the value of one to take care of today's higher line voltage...it should work out just fine.
Zenith with candohm resistor - by Eric Adams - 11-06-2014, 11:44 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-07-2014, 08:26 AM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 11:19 AM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 12:07 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-07-2014, 12:34 PM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 02:18 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-07-2014, 03:26 PM
RE: Zenith with candohm resistor - by Eric Adams - 11-07-2014, 03:40 PM
RE: Zenith with candohm resistor - by Phlogiston - 11-07-2014, 05:43 PM
RE: Zenith with candohm resistor - by Arran - 11-12-2014, 04:26 AM
RE: Zenith with candohm resistor - by Geoff - 11-11-2014, 02:04 PM
RE: Zenith with candohm resistor - by Phlogiston - 11-12-2014, 11:41 AM
RE: Zenith with candohm resistor - by Eric Adams - 11-13-2014, 10:43 PM
RE: Zenith with candohm resistor - by Ron Ramirez - 11-13-2014, 11:49 PM
RE: Zenith with candohm resistor - by jcassity - 04-02-2017, 11:04 AM
RE: Zenith with candohm resistor - by morzh - 04-02-2017, 01:49 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6169 online users. [Complete List]
» 1 Member(s) | 6168 Guest(s)
