Dial cord restring question
I had the same problem on a 40-190 recently. One segment was tight, the other loose. I worked the tuning knob back and forth a few times, and the tension evened out, as tab10672 suggested.
The next day, though, the string had stretched a little, so it was too loose again, and the cord slipped. I took one end off and shortened it a little, put it back on, worked the tuner back and forth a time or two, and it all works fine now.
John Honeycutt
Dial cord restring question - by ODPILOT - 11-07-2014, 05:46 PM
RE: Dial cord restring question - by tab10672 - 11-07-2014, 11:45 PM
RE: Dial cord restring question - by Raleigh - 11-07-2014, 11:57 PM
RE: Dial cord restring question - by ODPILOT - 11-08-2014, 11:48 AM
There are currently 10039 online users. [Complete List]
» 2 Member(s) | 10037 Guest(s)
