Philco Canada 39 or 41-722 Tropic
 I think I know what you meant about the speaker connector, there was a three pin type used in some Canadian RCA and G.E models in the early 40s, but I don't think any of my sets use them, the pin spacing is the same as a three pin "B" battery plug, I believe that they were made by Ebby. I think I may have some someplace. With regard to the volume control, sometimes you can swap shafts and wiper between controls, if they are both controls of the same make, that "C" clip can be pried out and pressed back on.
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-05-2014, 11:12 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-08-2014, 01:36 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-08-2014, 11:57 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-09-2014, 12:18 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-09-2014, 11:44 AM
RE: Philco Canada 39 or 41-722 Tropic - by Warren - 11-09-2014, 11:32 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-10-2014, 12:58 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-11-2014, 12:45 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-12-2014, 03:47 AM
RE: Philco Canada 39 or 41-722 Tropic - by sam - 11-12-2014, 04:56 AM
RE: Philco Canada 39 or 41-722 Tropic - by KCMike - 11-12-2014, 08:19 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-13-2014, 01:30 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-14-2014, 03:04 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
