AK808A
#35
Some wires:
This is the black wire:
This is the beige wire:
I have a piece of white (looks beige) insulation, I was able to tie a nod out of it, very nice and pliable. Did not degrade a bit. None of them did.
But all black ones are fully crumbled.
This is how the working surface looks due to it.
AK808A - by morzh - 10-29-2014, 08:57 PM
RE: AK808A - by Arran - 10-30-2014, 12:36 AM
RE: AK808A - by morzh - 10-30-2014, 11:20 AM
RE: AK808A - by fields 100 - 10-30-2014, 06:13 PM
RE: AK808A - by morzh - 10-30-2014, 07:24 PM
RE: AK808A - by fields 100 - 10-30-2014, 08:00 PM
RE: AK808A - by morzh - 10-30-2014, 10:42 PM
RE: AK808A - by fields 100 - 10-31-2014, 08:27 AM
RE: AK808A - by thirtiesradio - 10-31-2014, 10:39 PM
RE: AK808A - by fields 100 - 10-31-2014, 11:25 PM
RE: AK808A - by Arran - 11-01-2014, 04:29 AM
RE: AK808A - by thirtiesradio - 11-01-2014, 09:39 PM
RE: AK808A - by fields 100 - 11-01-2014, 06:22 AM
RE: AK808A - by thirtiesradio - 11-01-2014, 09:35 PM
RE: AK808A - by Arran - 11-02-2014, 12:30 AM
RE: AK808A - by thirtiesradio - 11-02-2014, 03:08 AM
RE: AK808A - by morzh - 11-02-2014, 04:02 PM
RE: AK808A - by morzh - 11-03-2014, 10:48 PM
RE: AK808A - by morzh - 11-05-2014, 11:55 PM
RE: AK808A - by thirtiesradio - 11-06-2014, 01:51 AM
RE: AK808A - by fields 100 - 11-06-2014, 07:23 AM
RE: AK808A - by morzh - 11-06-2014, 02:41 PM
RE: AK808A - by fields 100 - 11-06-2014, 08:12 PM
RE: AK808A - by Arran - 11-06-2014, 11:49 PM
RE: AK808A - by thirtiesradio - 11-07-2014, 01:15 AM
RE: AK808A - by morzh - 11-07-2014, 12:34 AM
RE: AK808A - by Arran - 11-07-2014, 02:31 AM
RE: AK808A - by Phlogiston - 11-07-2014, 03:12 AM
RE: AK808A - by morzh - 11-07-2014, 10:55 AM
RE: AK808A - by thirtiesradio - 11-07-2014, 05:58 PM
RE: AK808A - by thirtiesradio - 11-07-2014, 09:27 PM
RE: AK808A - by morzh - 11-07-2014, 09:39 PM
RE: AK808A - by morzh - 11-07-2014, 09:40 PM
RE: AK808A - by morzh - 11-09-2014, 08:58 PM
RE: AK808A - by morzh - 11-09-2014, 09:03 PM
RE: AK808A - by Arran - 11-11-2014, 05:56 AM
RE: AK808A - by morzh - 11-11-2014, 09:27 PM
RE: AK808A - by morzh - 11-13-2014, 10:40 PM
RE: AK808A - by morzh - 12-06-2014, 08:26 PM
RE: AK808A - by morzh - 12-06-2014, 10:51 PM
RE: AK808A - by morzh - 12-07-2014, 12:36 AM
RE: AK808A - by sam - 12-07-2014, 03:33 AM
RE: AK808A - by Radioroslyn - 12-07-2014, 03:50 AM
RE: AK808A - by morzh - 12-07-2014, 10:25 AM
RE: AK808A - by Radioroslyn - 12-07-2014, 10:33 AM
RE: AK808A - by morzh - 12-07-2014, 11:26 AM
RE: AK808A - by morzh - 12-07-2014, 11:33 AM
RE: AK808A - by Eliot Ness - 12-07-2014, 11:57 AM
RE: AK808A - by morzh - 12-07-2014, 12:05 PM
RE: AK808A - by morzh - 12-07-2014, 01:10 PM
RE: AK808A - by AI2V - 12-10-2014, 09:58 PM
RE: AK808A - by morzh - 12-10-2014, 11:33 PM
RE: AK808A - by thirtiesradio - 12-12-2014, 11:13 AM
RE: AK808A - by morzh - 12-12-2014, 02:44 PM
RE: AK808A - by thirtiesradio - 12-12-2014, 04:35 PM
RE: AK808A - by morzh - 12-12-2014, 05:09 PM
RE: AK808A - by thirtiesradio - 12-12-2014, 05:33 PM
RE: AK808A - by morzh - 12-14-2014, 10:38 PM
RE: AK808A - by morzh - 12-19-2014, 10:08 PM
RE: AK808A - by sam - 12-19-2014, 11:01 PM
RE: AK808A - by Arran - 12-20-2014, 02:42 AM
RE: AK808A - by morzh - 12-19-2014, 11:35 PM
RE: AK808A - by sam - 12-19-2014, 11:48 PM
RE: AK808A - by morzh - 12-20-2014, 12:39 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
