Feeling the current ....
Arran - interesting question about whether or not I feel the current with the radio on or off. When I got home from work - and checked it out - here's something that I didn't expect: With the radio ON and the cord plugged in the "wrong" way - I can feel the current. With the radio OFF and the cord in the "wrong" position, there is no current I can feel. However, with the radio OFF, if then I then reverse the plug, I can feel the current with the radio off. Is that weird, or does that somehow make sense?
Feeling the current .... - by ODPILOT - 11-09-2014, 07:50 PM
RE: Feeling the current .... - by Mondial - 11-09-2014, 08:22 PM
RE: Feeling the current .... - by morzh - 11-09-2014, 08:42 PM
RE: Feeling the current .... - by ODPILOT - 11-09-2014, 09:13 PM
RE: Feeling the current .... - by Arran - 11-10-2014, 01:31 AM
RE: Feeling the current .... - by morzh - 11-10-2014, 10:15 AM
RE: Feeling the current .... - by ODPILOT - 11-10-2014, 09:22 PM
RE: Feeling the current .... - by ODPILOT - 11-10-2014, 09:24 PM
RE: Feeling the current .... - by morzh - 11-10-2014, 11:33 PM
RE: Feeling the current .... - by mikethedruid - 11-11-2014, 06:17 AM
RE: Feeling the current .... - by PAradiogeek - 11-11-2014, 07:36 AM
RE: Feeling the current .... - by morzh - 11-11-2014, 12:16 PM
RE: Feeling the current .... - by ODPILOT - 11-11-2014, 02:17 PM
RE: Feeling the current .... - by morzh - 11-11-2014, 02:32 PM
RE: Feeling the current .... - by ODPILOT - 11-12-2014, 07:24 PM
RE: Feeling the current .... - by morzh - 11-12-2014, 08:00 PM
RE: Feeling the current .... - by Arran - 11-14-2014, 03:25 AM
RE: Feeling the current .... - by codefox1 - 11-15-2014, 04:39 PM
RE: Feeling the current .... - by morzh - 11-15-2014, 05:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
