Feeling the current ....
Odd,
Here is an explanation that I always found easy to understand. It says the same things Arran told you, but in a slightly different way. Sometimes hearing essentially the same thing with different words, helps us understand.
http://www.antiqueradio.org/safety.htm
Feeling the current .... - by ODPILOT - 11-09-2014, 07:50 PM
RE: Feeling the current .... - by Mondial - 11-09-2014, 08:22 PM
RE: Feeling the current .... - by morzh - 11-09-2014, 08:42 PM
RE: Feeling the current .... - by ODPILOT - 11-09-2014, 09:13 PM
RE: Feeling the current .... - by Arran - 11-10-2014, 01:31 AM
RE: Feeling the current .... - by morzh - 11-10-2014, 10:15 AM
RE: Feeling the current .... - by ODPILOT - 11-10-2014, 09:22 PM
RE: Feeling the current .... - by ODPILOT - 11-10-2014, 09:24 PM
RE: Feeling the current .... - by morzh - 11-10-2014, 11:33 PM
RE: Feeling the current .... - by mikethedruid - 11-11-2014, 06:17 AM
RE: Feeling the current .... - by PAradiogeek - 11-11-2014, 07:36 AM
RE: Feeling the current .... - by morzh - 11-11-2014, 12:16 PM
RE: Feeling the current .... - by ODPILOT - 11-11-2014, 02:17 PM
RE: Feeling the current .... - by morzh - 11-11-2014, 02:32 PM
RE: Feeling the current .... - by ODPILOT - 11-12-2014, 07:24 PM
RE: Feeling the current .... - by morzh - 11-12-2014, 08:00 PM
RE: Feeling the current .... - by Arran - 11-14-2014, 03:25 AM
RE: Feeling the current .... - by codefox1 - 11-15-2014, 04:39 PM
RE: Feeling the current .... - by morzh - 11-15-2014, 05:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
