Newbie Neophyte Question
Thank you for allowing me post my question here, and your informative reply! Boy, do I feel like a horse's rear! Well, it's on to the push buttons and perhaps a little refinishing work then- I believe I'll also explore the 41-295's problem as well this winter, as I hear it's supposed to be a long one this year... Thanks -Betruger-
Newbie Neophyte Question - by Guest - 11-15-2008, 10:23 AM
Re: Newbie Neophyte Question - by Ron Ramirez - 11-15-2008, 10:36 AM
Re: Newbie Neophyte Question - by Guest - 11-15-2008, 01:19 PM
Re: Newbie Neophyte Question - by Ron Ramirez - 11-15-2008, 02:47 PM
Re: Newbie Neophyte Question - by Texasrocker - 11-16-2008, 12:01 AM
Re: Newbie Neophyte Question - by Guest - 11-16-2008, 02:27 PM
Re: Newbie Neophyte Question - by Jim Berg - 11-20-2008, 10:49 PM
Re: Newbie Neophyte Question - by Ron Ramirez - 11-20-2008, 11:16 PM
Philco 91 Tuning Condenser
There are currently 8762 online users. [Complete List]
» 1 Member(s) | 8761 Guest(s)
