Philco Canada 39 or 41-722 Tropic
#35
One more photo:
[Image: http://www.philcoradio.com/images/phorum...e00034.jpg]
I really should go back in and add some spacers between chassis and cabinet; the chassis should be about 1/16 to 1/8" higher than it currently is. But it looks pretty good and sounds great.
I will probably replace the grille cloth at some point; I doubt this cloth is original.
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-05-2014, 11:12 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-08-2014, 01:36 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-08-2014, 11:57 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-09-2014, 12:18 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-09-2014, 11:44 AM
RE: Philco Canada 39 or 41-722 Tropic - by Warren - 11-09-2014, 11:32 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-10-2014, 12:58 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-11-2014, 12:45 AM
RE: Philco Canada 39 or 41-722 Tropic - by Ron Ramirez - 11-11-2014, 03:50 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-12-2014, 03:47 AM
RE: Philco Canada 39 or 41-722 Tropic - by sam - 11-12-2014, 04:56 AM
RE: Philco Canada 39 or 41-722 Tropic - by KCMike - 11-12-2014, 08:19 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-13-2014, 01:30 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-14-2014, 03:04 AM
Users browsing this thread: 19 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6965 online users. [Complete List]
» 1 Member(s) | 6964 Guest(s)
