Advice on output transformer
  I'am working on an philco model 14lzx it has two speakers H-7 & K12 it has 2-42 push/pull output tubes.
Would a hammond 125D ot trans. work for this? oops wrong thread!! Hope moderator can move.
Advice on output transformer - by KCMike - 11-11-2014, 10:12 PM
RE: Advice on output transformer - by Ron Ramirez - 11-11-2014, 10:52 PM
RE: Advice on output transformer - by morzh - 11-12-2014, 10:39 AM
RE: Advice on output transformer - by KCMike - 11-12-2014, 10:43 AM
