Setchell-Carlson ID
Just thought I'd update the group, the radio in question is a model 55. Schematics were located so all is good there.
John
Setchell-Carlson ID - by phly guy - 09-30-2008, 10:13 AM
Re: Setchell-Carlson ID - by BDM - 09-30-2008, 12:12 PM
Re: Setchell-Carlson ID - by phly guy - 10-02-2008, 12:44 AM
Re: Setchell-Carlson ID - by phly guy - 10-02-2008, 08:56 AM
Re: Setchell-Carlson ID - by BDM - 10-02-2008, 09:26 AM
Re: Setchell-Carlson ID - by Doug Houston - 10-03-2008, 10:55 PM
Re: Setchell-Carlson ID - by phly guy - 10-24-2008, 08:59 AM
Re: Setchell-Carlson ID - by phly guy - 11-15-2008, 06:55 PM
There are currently 10437 online users. [Complete List]
» 1 Member(s) | 10436 Guest(s)
