Starting on Philco 90
Thanks morzh and Mondial. The micas on the trimmers is what I was concerned with.
The cap is fairly dirty under the plates, but I will try the light brushing and air first.
There is some rust on the upper edges of some of the rotor plates that goes maybe 1/4".
Should I just leave that alone?
Starting on Philco 90 - by KCMike - 11-12-2014, 01:07 PM
RE: Starting on Philco 90 - by morzh - 11-12-2014, 02:37 PM
RE: Starting on Philco 90 - by Mondial - 11-12-2014, 04:35 PM
RE: Starting on Philco 90 - by KCMike - 11-12-2014, 04:57 PM
RE: Starting on Philco 90 - by morzh - 11-12-2014, 05:02 PM
RE: Starting on Philco 90 - by KCMike - 11-16-2014, 07:15 PM
RE: Starting on Philco 90 - by Ron Ramirez - 11-16-2014, 09:51 PM
RE: Starting on Philco 90 - by KCMike - 11-20-2014, 05:09 PM
RE: Starting on Philco 90 - by morzh - 11-20-2014, 05:15 PM
RE: Starting on Philco 90 - by KCMike - 11-20-2014, 06:03 PM
RE: Starting on Philco 90 - by jerryhawthorne - 11-20-2014, 07:07 PM
RE: Starting on Philco 90 - by KCMike - 11-20-2014, 07:16 PM
RE: Starting on Philco 90 - by morzh - 11-20-2014, 08:20 PM
RE: Starting on Philco 90 - by Steve Davis - 11-21-2014, 08:03 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6713 online users. [Complete List]
» 1 Member(s) | 6712 Guest(s)
