Philco Canada 39 or 41-722 Tropic
#41
Ron,
 I also have asbestos under my chassis.  Here is a picture of my grill cloth.  I think it's original.
     I found my password and had to log in again to be able to add the picture.                                         Henry
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-05-2014, 11:12 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-08-2014, 01:36 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-08-2014, 11:57 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-09-2014, 12:18 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-09-2014, 11:44 AM
RE: Philco Canada 39 or 41-722 Tropic - by Warren - 11-09-2014, 11:32 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-10-2014, 12:58 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-11-2014, 12:45 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-12-2014, 03:47 AM
RE: Philco Canada 39 or 41-722 Tropic - by sam - 11-12-2014, 04:56 AM
RE: Philco Canada 39 or 41-722 Tropic - by radiohenry - 11-12-2014, 08:10 PM
RE: Philco Canada 39 or 41-722 Tropic - by KCMike - 11-12-2014, 08:19 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-13-2014, 01:30 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-14-2014, 03:04 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
