Philco Canada 39 or 41-722 Tropic
#44
I am not sure, and don't have the records handy to check, but one reason for the difference between US and Canadian wire type, rubber covered vs. cloth covered, could be a difference between UL and CSA requirements at the time. Having dealt with both, I know that CSA requirements are sometimes different and more conservative, even to this day. This might be an interesting bit of trivia for someone to investigate.
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-05-2014, 11:12 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-08-2014, 01:36 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-08-2014, 11:57 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-09-2014, 12:18 AM
RE: Philco Canada 39 or 41-722 Tropic - by Kekoa - 11-09-2014, 11:44 AM
RE: Philco Canada 39 or 41-722 Tropic - by Warren - 11-09-2014, 11:32 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-10-2014, 12:58 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-11-2014, 12:45 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-12-2014, 03:47 AM
RE: Philco Canada 39 or 41-722 Tropic - by sam - 11-12-2014, 04:56 AM
RE: Philco Canada 39 or 41-722 Tropic - by KCMike - 11-12-2014, 08:19 PM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-13-2014, 01:30 AM
RE: Philco Canada 39 or 41-722 Tropic - by mikethedruid - 11-13-2014, 08:34 AM
RE: Philco Canada 39 or 41-722 Tropic - by Arran - 11-14-2014, 03:04 AM
Users browsing this thread: 18 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7100 online users. [Complete List]
» 1 Member(s) | 7099 Guest(s)
