37-93 passed the smoke test!
The original pattern for the 37-93 is no longer produced by anyone.
Perhaps you might consider the Diamond Regular from Richmond Designs?
http://richmonddesignsinc.com/grille_cloth_product_page
37-93 passed the smoke test! - by DanH6464 - 11-14-2014, 03:37 AM
RE: 37-93 passed the smoke test! - by Ron Ramirez - 11-14-2014, 08:59 AM
RE: 37-93 passed the smoke test! - by PAradiogeek - 11-14-2014, 02:05 PM
RE: 37-93 passed the smoke test! - by DanH6464 - 11-14-2014, 03:26 PM
RE: 37-93 passed the smoke test! - by DanH6464 - 11-14-2014, 03:28 PM
RE: 37-93 passed the smoke test! - by DanH6464 - 11-18-2014, 04:27 AM
RE: 37-93 passed the smoke test! - by Warren - 11-18-2014, 04:31 PM
RE: 37-93 passed the smoke test! - by KCMike - 11-18-2014, 06:37 PM
