Philco 70 with shortwave
Thank you Ron Icon_thumbup
This is much easier than I thought it would be.
Philco 70 with shortwave - by thirtiesradio - 11-14-2014, 02:53 PM
RE: Philco 70 with shortwave - by Ron Ramirez - 11-14-2014, 03:28 PM
RE: Philco 70 with shortwave - by thirtiesradio - 11-14-2014, 07:02 PM
There are currently 7865 online users. [Complete List]
» 1 Member(s) | 7864 Guest(s)
