Please help identify this Silvertone
Thanks. Yes, they're close but no match. Someone today told me it might be a 7181, but I can't find another picture of one to confirm that. All I know is that the chassis has a serial number on it, 7S-1089. Also, the receiver takes these seven tubes: 5Y3, 6C5, 6F6, 6K7, 6K7, 6L7, 6Q7
Please help identify this Silvertone - by Guest - 12-16-2008, 09:43 PM
Re: Please help identify this Silvertone - by BDM - 12-16-2008, 11:57 PM
Re: Please help identify this Silvertone - by Guest - 12-17-2008, 04:51 PM
Re: Please help identify this Silvertone - by Guest - 12-18-2008, 10:12 PM
Re: Please help identify this Silvertone - by Guest - 07-13-2010, 05:13 PM
Philco 91 Tuning Condenser
