Which inspired which?
Greg
I really had to stretch my imagination and have found a couple of similarities which, speaking of cars, existed in other makes and models. But it is hard for me to see direct semblance.
Which inspired which? - by NostalgiaRadioTime - 11-15-2014, 01:30 AM
RE: Which inspired which? - by morzh - 11-15-2014, 11:26 AM
RE: Which inspired which? - by NostalgiaRadioTime - 11-15-2014, 04:03 PM
RE: Which inspired which? - by 37silverstreak - 11-15-2014, 04:23 PM
RE: Which inspired which? - by Art Hoch - 11-18-2014, 09:25 PM
There are currently 4035 online users. [Complete List]
» 1 Member(s) | 4034 Guest(s)
