Question about a 53-960
Kekoa
(about el. caps) Try this: you are leaving the old ones in place, right?
You could possibly epoxy new cans (or hotglue) using a crease created by old caps' protruding parts and the chassis' surface as anchor, and then solder to them.
Question about a 53-960 - by Kekoa - 10-26-2014, 12:09 AM
RE: Question about a 53-960 - by sam - 10-26-2014, 12:16 AM
RE: Question about a 53-960 - by Ron Ramirez - 10-26-2014, 08:36 AM
RE: Question about a 53-960 - by radiohenry - 10-26-2014, 11:24 AM
RE: Question about a 53-960 - by Kekoa - 10-26-2014, 11:27 AM
RE: Question about a 53-960 - by OZ4 - 10-26-2014, 12:41 PM
RE: Question about a 53-960 - by Kekoa - 10-26-2014, 04:13 PM
RE: Question about a 53-960 - by Ron Ramirez - 10-26-2014, 04:20 PM
RE: Question about a 53-960 - by Kekoa - 10-26-2014, 05:47 PM
RE: Question about a 53-960 - by Kekoa - 10-27-2014, 12:29 PM
RE: Question about a 53-960 - by morzh - 10-27-2014, 10:13 PM
RE: Question about a 53-960 - by Arran - 10-28-2014, 12:02 AM
RE: Question about a 53-960 - by Kekoa - 10-28-2014, 10:11 AM
RE: Question about a 53-960 - by Kekoa - 11-02-2014, 09:12 PM
RE: Question about a 53-960 - by morzh - 11-02-2014, 09:27 PM
RE: Question about a 53-960 - by Kekoa - 11-03-2014, 12:36 PM
RE: Question about a 53-960 - by Kekoa - 11-06-2014, 01:30 AM
RE: Question about a 53-960 - by sam - 11-06-2014, 03:52 AM
RE: Question about a 53-960 - by Kekoa - 11-08-2014, 09:52 PM
RE: Question about a 53-960 - by Ron Ramirez - 11-08-2014, 11:43 PM
RE: Question about a 53-960 - by Kekoa - 11-15-2014, 11:48 AM
RE: Question about a 53-960 - by morzh - 11-15-2014, 11:55 AM
RE: Question about a 53-960 - by Kekoa - 11-15-2014, 12:09 PM
RE: Question about a 53-960 - by morzh - 11-15-2014, 03:31 PM
RE: Question about a 53-960 - by Ron Ramirez - 11-15-2014, 09:14 PM
RE: Question about a 53-960 - by Kekoa - 11-15-2014, 10:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6738 online users. [Complete List]
» 1 Member(s) | 6737 Guest(s)
