Which inspired which?
I was referring to the wrap around grill work on both. Granted, it is a stretch, but a fellow radio collector pointed this out to me. Of course, he also owns a '42 Chrysler in addition to a 42-350, so he may be somewhat biased Icon_smile
Which inspired which? - by NostalgiaRadioTime - 11-15-2014, 01:30 AM
RE: Which inspired which? - by morzh - 11-15-2014, 11:26 AM
RE: Which inspired which? - by NostalgiaRadioTime - 11-15-2014, 04:03 PM
RE: Which inspired which? - by 37silverstreak - 11-15-2014, 04:23 PM
RE: Which inspired which? - by Art Hoch - 11-18-2014, 09:25 PM
There are currently 2148 online users. [Complete List]
» 1 Member(s) | 2147 Guest(s)
