Which inspired which?
Hi Greg,
I think that both are good examples of styling tastes of that era. That Art Deco representation of aerodynamics and streamlining was very common. My 1937 Pontiac has a similar theme with a center band of chrome stripes running down the center of the hood and trunk lid. there is also the "waterfall" styling of furniture with curved corners and edges which you see a lot of in radio cabinets of the time.
Kevin
Which inspired which? - by NostalgiaRadioTime - 11-15-2014, 01:30 AM
RE: Which inspired which? - by morzh - 11-15-2014, 11:26 AM
RE: Which inspired which? - by NostalgiaRadioTime - 11-15-2014, 04:03 PM
RE: Which inspired which? - by 37silverstreak - 11-15-2014, 04:23 PM
RE: Which inspired which? - by Art Hoch - 11-18-2014, 09:25 PM
