Help on 48-482 FM
Some info on the FM1000 circuitry:
http://www.philcorepairbench.com/tube/fm1000.htm
http://www.antiqueradios.com/forums/view...f1f9274ac9
http://www.antiqueradios.com/forums/view...f4907cc80d
http://www.audiophool.cjb.net/Misc/philco_48-482.djvu (requires a DJVU reader)
http://www.antiqueradios.com/forums/view...8a749472fb
Terry Judkins, where are you??? Your expertise is needed here...
Help on 48-482 FM - by jerryhawthorne - 11-12-2008, 04:57 PM
Re: Help on 48-482 FM - by codefox1 - 11-14-2008, 02:42 PM
Re: Help on 48-482 FM - by jerryhawthorne - 11-14-2008, 03:55 PM
Re: Help on 48-482 FM - by jerryhawthorne - 11-15-2008, 10:00 PM
Re: Help on 48-482 FM - by Ron Ramirez - 11-16-2008, 03:13 PM
Re: Help on 48-482 FM - by jerryhawthorne - 11-16-2008, 08:35 PM
Re: Help on 48-482 FM - by Terry Judkins - 11-16-2008, 11:01 PM
Re: Help on 48-482 FM - by jerryhawthorne - 11-17-2008, 08:01 PM
Re: Help on 48-482 FM - by Terry Judkins - 11-17-2008, 08:27 PM
Re: Help on 48-482 FM - by jerryhawthorne - 11-18-2008, 10:01 PM
