Microwave Woodworm
#46
Ex Ray is on the ball on this one, I worked for an import company once, anytime you buy something made overseas ask yourself did that 40 ft' container get fumigated? Many time they do as customs will even notice bugs in their spotty inspections. It is a bigger issue than you may think.
Microwave Woodworm - by HOTWIRE - 10-20-2014, 10:05 PM
RE: Microwave Woodworm - by Arran - 10-20-2014, 10:53 PM
RE: Microwave Woodworm - by morzh - 10-21-2014, 12:00 AM
RE: Microwave Woodworm - by Warren - 10-21-2014, 12:13 AM
RE: Microwave Woodworm - by Eliot Ness - 10-21-2014, 07:43 AM
RE: Microwave Woodworm - by Phlogiston - 10-21-2014, 11:11 AM
RE: Microwave Woodworm - by HOTWIRE - 10-21-2014, 11:57 AM
RE: Microwave Woodworm - by HOTWIRE - 10-21-2014, 12:16 PM
RE: Microwave Woodworm - by Ron Ramirez - 10-21-2014, 12:24 PM
RE: Microwave Woodworm - by Eliot Ness - 10-21-2014, 01:34 PM
RE: Microwave Woodworm - by Phlogiston - 10-21-2014, 03:13 PM
RE: Microwave Woodworm - by HOTWIRE - 10-21-2014, 04:10 PM
RE: Microwave Woodworm - by HOTWIRE - 10-21-2014, 06:29 PM
RE: Microwave Woodworm - by keithw - 10-21-2014, 07:21 PM
RE: Microwave Woodworm - by Arran - 10-22-2014, 01:51 AM
RE: Microwave Woodworm - by PhilcoJohn - 10-22-2014, 09:45 AM
RE: Microwave Woodworm - by Ron Ramirez - 10-22-2014, 09:48 AM
RE: Microwave Woodworm - by HOTWIRE - 10-22-2014, 06:05 PM
RE: Microwave Woodworm - by Phlogiston - 10-22-2014, 06:23 PM
RE: Microwave Woodworm - by HOTWIRE - 10-22-2014, 07:05 PM
RE: Microwave Woodworm - by Phlogiston - 10-22-2014, 10:00 PM
RE: Microwave Woodworm - by Arran - 10-22-2014, 10:01 PM
RE: Microwave Woodworm - by HOTWIRE - 10-23-2014, 08:54 AM
RE: Microwave Woodworm - by Alan Douglas - 10-23-2014, 11:40 AM
RE: Microwave Woodworm - by Phlogiston - 10-23-2014, 12:02 PM
RE: Microwave Woodworm - by HOTWIRE - 10-23-2014, 06:10 PM
RE: Microwave Woodworm - by Alan Douglas - 10-23-2014, 07:18 PM
RE: Microwave Woodworm - by Warren - 10-23-2014, 08:09 PM
RE: Microwave Woodworm - by Arran - 10-24-2014, 01:34 AM
RE: Microwave Woodworm - by Phlogiston - 10-24-2014, 01:53 AM
RE: Microwave Woodworm - by Arran - 10-24-2014, 03:25 AM
RE: Microwave Woodworm - by HOTWIRE - 11-06-2014, 03:48 PM
RE: Microwave Woodworm - by Ron Ramirez - 11-06-2014, 11:29 PM
RE: Microwave Woodworm - by Warren - 11-07-2014, 03:43 PM
RE: Microwave Woodworm - by Phlogiston - 11-07-2014, 05:17 PM
RE: Microwave Woodworm - by Arran - 11-08-2014, 01:18 AM
RE: Microwave Woodworm - by Alan Douglas - 11-08-2014, 09:31 AM
RE: Microwave Woodworm - by Phlogiston - 11-08-2014, 12:02 PM
RE: Microwave Woodworm - by Alan Douglas - 11-08-2014, 07:01 PM
RE: Microwave Woodworm - by exray - 11-08-2014, 07:39 PM
RE: Microwave Woodworm - by exray - 11-08-2014, 07:52 PM
RE: Microwave Woodworm - by Ron Ramirez - 11-09-2014, 09:16 AM
RE: Microwave Woodworm - by exray - 11-09-2014, 09:32 PM
RE: Microwave Woodworm - by codefox1 - 11-13-2014, 06:34 PM
RE: Microwave Woodworm - by HOTWIRE - 11-14-2014, 08:40 AM
RE: Microwave Woodworm - by Paul Philco322 - 11-16-2014, 09:59 AM
RE: Microwave Woodworm - by lacountyretired - 11-16-2014, 02:33 PM
RE: Microwave Woodworm - by exray - 11-16-2014, 06:47 PM
RE: Microwave Woodworm - by Eric T - 01-03-2015, 02:18 PM
RE: Microwave Woodworm - by HOTWIRE - 01-03-2015, 08:21 PM
There are currently 10544 online users. [Complete List]
» 2 Member(s) | 10542 Guest(s)
