High Plate Voltage on IF tube 39-116
I pulled the 2nd IF transformer and in examining it it appears one of the solder joints of the new wiring was grounding to the exterior shield of the transformer. Readings are all good and I attached it with patch cords and now there is considerably more static etc.
What has anyone used to firm up the tiny coil wires? I have one that the wax has come off and it is separated into multiple tiny strands. I was thinking maybe nail polish?
Thanks for your assistance.
Jeff
RE: High Plate Voltage on IF tube 39-116 - by jeffgniffke - 11-16-2014, 05:48 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 3907 online users. [Complete List]
» 4 Member(s) | 3903 Guest(s)
AvatarAvatarAvatarAvatar
