116X alignment tools
Ronin
Many of us made one from a plastic ballpen, by heating it up and morfing it around a proper size nut or standoff.
116X alignment tools - by Ronin61 - 11-16-2014, 03:37 PM
RE: 116X alignment tools - by sam - 11-16-2014, 03:55 PM
RE: 116X alignment tools - by morzh - 11-16-2014, 06:15 PM
RE: 116X alignment tools - by thirtiesradio - 11-16-2014, 06:29 PM
RE: 116X alignment tools - by Ronin61 - 11-16-2014, 11:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
