37-93 recapped but its a hummer
I have a set of tubes coming from tubes and more but still haven't arrived. Might just hit myself with the mallet instead lol
37-93 recapped but its a hummer - by DanH6464 - 11-14-2014, 04:40 PM
RE: 37-93 recapped but its a hummer - by DanH6464 - 11-14-2014, 05:54 PM
RE: 37-93 recapped but its a hummer - by OZ4 - 11-15-2014, 10:55 PM
RE: 37-93 recapped but its a hummer - by DanH6464 - 11-16-2014, 11:50 PM
RE: 37-93 recapped but its a hummer - by DanH6464 - 11-17-2014, 12:31 AM
RE: 37-93 recapped but its a hummer - by DanH6464 - 11-17-2014, 01:11 AM
RE: 37-93 recapped but its a hummer - by DanH6464 - 11-17-2014, 01:16 AM
RE: 37-93 recapped but its a hummer - by DanH6464 - 11-17-2014, 01:36 AM
RE: 37-93 recapped but its a hummer - by Mondial - 11-17-2014, 09:37 AM
RE: 37-93 recapped but its a hummer - by Arran - 11-17-2014, 02:41 PM
RE: 37-93 recapped but its a hummer - by DanH6464 - 11-18-2014, 03:54 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
