wireless Phono
My guess, looking at the 1941 and 42 product cut sheets, is a 42-RP2, since the case is smooth, the 41-RP2 has a moulded front on the lower case. Circuit-wise they are almost identical, between the 41 and 42 versions. Case may also have been refinished at one time, since the photo-finish "veneer-inlay" strip is missing on the lower case.
{EDIT, later that same morning.} Ok, maybe not....... Icon_smile
wireless Phono - by Chris Drumma - 12-18-2005, 11:29 AM
[No subject] - by Ron Ramirez - 12-18-2005, 11:45 AM
[No subject] - by Chuck Schwark - 12-18-2005, 11:48 AM
[No subject] - by Ron Ramirez - 12-18-2005, 11:59 AM
[No subject] - by Chris Drumma - 12-18-2005, 01:14 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:13 AM
[No subject] - by Chris Drumma - 12-22-2005, 01:35 PM
[No subject] - by Ron Ramirez - 12-22-2005, 05:35 PM
Philco 91 Tuning Condenser
