38-690 W-6 Speaker Field
I have a 38-690 with open field coil, and Riders doesn't provide a value for the resistance. Ideally, I would like to find a replacement W-6 speaker, failing that, I could use help in best method to remove old coil. Can't get to the bottom of the rivets to remove frame from horseshoe holding coil. Considering cutting off the horseshoe near frame. I located a place on the winding that looks like a tap, mesures about 200 ohm. The notes I have with this radio indicate previous owner thought the resistance was 4300 ohms...sounds really high to me.
38-690 W-6 Speaker Field - by Guest - 11-17-2008, 09:50 AM
Re: 38-690 W-6 Speaker Field - by Terry Burns - 11-17-2008, 11:07 AM
There are currently 10200 online users. [Complete List]
» 3 Member(s) | 10197 Guest(s)
