Model 41-250 Band Lamp
While I'm waiting for the part for my 610 to come in, I pulled out a 41-250 that I had in the garage.There is a lamp behind the glass dial that I think moves with the band switch but the dial cord to that lamp is hanging loose. I have not been able to find any info on how this dial cord is run in my web search. I would appreciate info on how this cord is strung from someonewho has this radio. Another item in question on this radio is that on the 2 stage tuning cap, there is a trimmer on top of one section and there is a wire that is about 3 inches coming off of this trimmer into thin air. Where should this wire go to? This radio has had some rework done to it (84 replaced with 7Z4, volume control changed to one with on/off switch, and some other small items) so I don't know if something is missing. Thanks.
Harv
Model 41-250 Band Lamp - by mandh - 11-17-2008, 07:49 PM
Re: Model 41-250 Band Lamp - by Terry Judkins - 11-18-2008, 12:35 AM
Re: Model 41-250 Band Lamp - by mandh - 11-18-2008, 09:06 AM
Re: Model 41-250 Band Lamp - by Raleigh - 11-19-2008, 10:51 AM
Re: Model 41-250 Band Lamp - by mandh - 11-24-2008, 08:19 AM
There are currently 10524 online users. [Complete List]
» 3 Member(s) | 10521 Guest(s)
