wireless Phono
This is a 42-RP2:
[Image: http://www.philcoradio.com/gallery/image...42rp2o.jpg]
(Photo credit: Bob Timms)
Notice that this one has no half-round moldings, and it is wider at the base.
(edit) Now, a mid-season 1939 Model RP-2, which is identical with the item on our favorite online auction site:
[Image: http://www.philcoradio.com/gallery/images/1939/rp2o.jpg]
wireless Phono - by Chris Drumma - 12-18-2005, 11:29 AM
[No subject] - by Ron Ramirez - 12-18-2005, 11:45 AM
[No subject] - by Chuck Schwark - 12-18-2005, 11:48 AM
[No subject] - by Ron Ramirez - 12-18-2005, 11:59 AM
[No subject] - by Chris Drumma - 12-18-2005, 01:14 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:13 AM
[No subject] - by Chris Drumma - 12-22-2005, 01:35 PM
[No subject] - by Ron Ramirez - 12-22-2005, 05:35 PM
Philco 91 Tuning Condenser
