Bakelite Capacitor and Resistor Blocks
Robin
If you go here:
http://www.nostalgiaair.org/PagesByModel...013793.pdf
(the link Sam gave you)
And look at the sch, part 49 ( 3793-W, which is your part) you will see it is 0.015uF capacitor.
For substitute use any adequate line voltage (250AC) Y-rated safety cap.
Same sch has other parts like 3903-AP which is #30, 0.01uF. The voltage at the position 30 can be 100V, quite enough.
Etc.
Bakelite Capacitor and Resistor Blocks - by Robin R. Roeckers - 11-20-2014, 03:08 PM
RE: Bakelite Capacitor and Resistor Blocks - by morzh - 11-20-2014, 03:52 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
