need help 620 blocks (4989-DG)
You should be using metalized film capacitors such as these:
http://www.radiodaze.com/product/62.aspx
These are small enough to fit inside the bakelite block.
You can get them from many sources besides Radio Daze.
Just Radios - http://www.justradios.com/
Bob's Antique Radios - http://www.radioantiques.com/supplies.html#caps <---my favorite cap supplier
Sal's Capacitor Corner - http://www.tuberadios.com/capacitors/
RE: need help 620 blocks (4989-DG) - by Ron Ramirez - 11-20-2014, 11:18 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
