  • 1 Vote(s) - 5 Average
Next case - Odd Philco 42-720 Tropic
#69
Okay!
Since I last posted in this thread, I recapped my 53-960 - you can read about that here.
I have sent the 42-720's dial back plate off to Greg (NostalgiaRadioTime) to let him work his magic on it.
And now I have a new Hammond 270EX transformer.
It is longer than the original, plus it has wires protruding from both bells. The original had all of the wires coming from just one bell. So...that meant drilling and enlarging a second hole for some of the transformer leads.
Here's how it looks:
[Image: http://www.philcoradio.com/images/phorum...e00030.jpg]
[Image: http://www.philcoradio.com/images/phorum...e00031.jpg]
[Image: http://www.philcoradio.com/images/phorum...e00032.jpg]
I'm using only three screws to hold it onto the chassis; the fourth screw hole would be right above where the audio output transformer is mounted, so it could not be used.
I probably should have purchased the 270DX instead; that would have allowed me to reuse the original transformer bells. But this one has plenty of reserve current capacity and should never run hot. With all of that iron, it looks like a 25 cycle transformer (even though it isn't)!
This transformer has a 5 volt winding as well as a 6.3 volt winding, so I rewired the 6X5 tube socket to accept a 5Y3GT instead. The 5Y3GT is a more robust rectifier, and this mod should eliminate the possibility of a shorted rectifier tube.
RE: Next case - Odd Philco 42-720 Tropic - by sam - 10-30-2014, 03:55 AM
RE: Next case - Odd Philco 42-720 Tropic - by Ron Ramirez - 11-22-2014, 11:56 AM
Users browsing this thread: 18 Guest(s)
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
