  • 1 Vote(s) - 3 Average
Weight of 680x
bobyoung53
welcome to the phorum
I would think its close to what he says. chassis and speaker weigh the most cabinet is nothing
sam
Weight of 680x - by bobyoung53 - 11-22-2014, 02:40 PM
RE: Weight of 36-680x - by sam - 11-22-2014, 06:13 PM
RE: Weight of 36-680x - by bobyoung53 - 11-22-2014, 06:42 PM
RE: Weight of 36-680x - by bobyoung53 - 11-22-2014, 06:51 PM
RE: Weight of 36-680x - by morzh - 11-22-2014, 07:12 PM
RE: Weight of 36-680x - by bobyoung53 - 11-23-2014, 04:40 AM
RE: Weight of 36-680x - by Arran - 11-23-2014, 05:01 AM
RE: Weight of 36-680x - by bobyoung53 - 11-23-2014, 05:10 AM
RE: Weight of 680x - by Ron Ramirez - 11-23-2014, 08:55 AM
RE: Weight of 680x - by morzh - 11-23-2014, 11:27 AM
RE: Weight of 680x - by Ron Ramirez - 11-23-2014, 12:43 PM
RE: Weight of 680x - by morzh - 11-23-2014, 10:29 PM
RE: Weight of 680x - by Arran - 11-25-2014, 06:05 AM
RE: Weight of 680x - by y2kbruce - 11-25-2014, 07:16 PM
RE: Weight of 680x - by thirtiesradio - 11-26-2014, 02:10 AM
There are currently 9959 online users. [Complete List]
» 3 Member(s) | 9956 Guest(s)
