40-195 Crackly Sound
Does it only makes the crackling sound when you touch the 7G7 tube? A crackly sound usually indicates an intermittent connection somewhere. I keep a plastic stick for when I have a problem like this. I will lightly tap on each component until I find the culprit.
40-195 Crackly Sound - by dfields69 - 11-23-2014, 12:07 PM
RE: 40-195 Crackly Sound - by Jeremy S - 11-24-2014, 10:36 AM
RE: 40-195 Crackly Sound - by Jeremy S - 11-24-2014, 01:56 PM
RE: 40-195 Crackly Sound - by dfields69 - 11-25-2014, 06:30 PM
RE: 40-195 Crackly Sound - by David - 11-25-2014, 03:29 PM
RE: 40-195 Crackly Sound - by dfields69 - 11-25-2014, 06:34 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
