MODEL 43 - REPAIR DE-LAMINATED PLYWOOD IN BASE OF RADIO CABINET
I have been able to get Elmers wood glue into a syringe with a pretty large gauge needle (its blunt for glue applications).  It doesn't suck up into the syringe like water but does slowly fill the syringe.  I was mostly gluing down delaminated veneer although some of the underlying wood also needed some glue.  I used wax paper between the glued veneer and the wood used to provide even clamping under the C-clamps.
[Image: https://dl.dropboxusercontent.com/u/5462...yringe.jpg]
There are currently 8615 online users. [Complete List]
» 3 Member(s) | 8612 Guest(s)
