xf 19
Welcome Turtle! Can you post a pic of your Philco model xf19? If so, that would help alot in determining the value for your resale-value question. Im confident that it would be worth your time posting a pic of your Philco xf19 here, and perhaps we can help you find more info on it as well? Icon_wink
xf 19 - by Guest - 11-19-2008, 10:33 PM
Re: xf 19 - by Texasrocker - 11-20-2008, 02:39 AM
Re: xf 19 - by Guest - 11-30-2008, 07:22 PM
Re: xf 19 - by Guest - 12-03-2008, 01:35 AM
Re: xf 19 - by Ron Ramirez - 12-03-2008, 07:50 AM
Re: xf 19 - by Guest - 12-03-2008, 10:03 PM
Re: xf 19 - by Chuck Schwark - 12-03-2008, 10:11 PM
Re: xf 19 - by Ron Ramirez - 12-03-2008, 10:52 PM
Re: xf 19 - by Guest - 12-09-2008, 12:44 AM
Re: xf 19 - by Ron Ramirez - 12-09-2008, 02:13 PM
Re: xf 19 - by Guest - 12-14-2008, 09:15 PM
