Best Philco Radio-Phono-TV combination?
I keep seeing the 49-1077 style and a slightly different 12 inch roundie. Also have seen a few 14 inch combos with the square CRT, but they seem to be demanding insane prices from the sellers.
RE: Best Philco Radio-Phono-TV combination? - by Jayce - 11-24-2014, 08:06 PM
There are currently 6764 online users. [Complete List]
» 2 Member(s) | 6762 Guest(s)
