Model 43 - Speaker re-coning
Rich Stamer, Sound Remedy in NJ. Good guy, good work, good prices. Google him up.
Good luck
Model 43 - Speaker re-coning - by jhgrahamjr - 11-24-2014, 02:04 PM
RE: Model 43 - Speaker re-coning - by morzh - 11-24-2014, 02:41 PM
RE: Model 43 - Speaker re-coning - by klondike98 - 11-24-2014, 03:13 PM
RE: Model 43 - Speaker re-coning - by klondike98 - 11-24-2014, 04:09 PM
RE: Model 43 - Speaker re-coning - by jhgrahamjr - 11-24-2014, 05:52 PM
RE: Model 43 - Speaker re-coning - by Paul Philco322 - 11-24-2014, 09:17 PM
RE: Model 43 - Speaker re-coning - by jhgrahamjr - 11-24-2014, 10:23 PM
RE: Model 43 - Speaker re-coning - by Eric Adams - 11-25-2014, 12:44 AM
RE: Model 43 - Speaker re-coning - by jhgrahamjr - 11-25-2014, 12:22 PM
RE: Model 43 - Speaker re-coning - by PAradiogeek - 11-26-2014, 02:09 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
