Model 43 - Speaker re-coning
Glad to hear this, Eric! I have contacted Rich and will send him my speaker for the re-coning while I do tedious cosmetic restoration on the chassis--lots of light corrosion on the (cadmium?) plated surface. When I get the speaker back, I can start re-capping, etc., and hear confirmation of my progress, or lack thereof! I am assuming he will use the original spider and field coil, etc., and incorporate them in the re-coning? I would like them to remain.
Model 43 - Speaker re-coning - by jhgrahamjr - 11-24-2014, 02:04 PM
RE: Model 43 - Speaker re-coning - by morzh - 11-24-2014, 02:41 PM
RE: Model 43 - Speaker re-coning - by klondike98 - 11-24-2014, 03:13 PM
RE: Model 43 - Speaker re-coning - by klondike98 - 11-24-2014, 04:09 PM
RE: Model 43 - Speaker re-coning - by jhgrahamjr - 11-24-2014, 05:52 PM
RE: Model 43 - Speaker re-coning - by jhgrahamjr - 11-24-2014, 10:23 PM
RE: Model 43 - Speaker re-coning - by Eric Adams - 11-25-2014, 12:44 AM
RE: Model 43 - Speaker re-coning - by jhgrahamjr - 11-25-2014, 12:22 PM
RE: Model 43 - Speaker re-coning - by PAradiogeek - 11-26-2014, 02:09 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
